- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, stream)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello,
I have been using the R7100LG for several months without any noticeable issue until I started using video conferencing (Skype for business, formerly Microsoft Lync) on a regular basis leveraging screen sharing as a way to present slides to a remote audience.
ISSUE: The internet connection interrupts for 2 seconds then reconnects *every hour exactly*.
As a result my screen sharing stops; I have to wait for the reconnection and rejoin the meeting then reshare my screen with my customer which is big inconvenience sometimes.I face similar issues although with much less business impact when watching streaming videos (it pauses 2/3 seconds then restarts) or playing video games (I get kicked out of battle net).
Notes:
- Interruption occurs exactly every 1 hour (I spend a lot of time testing with Lync screen sharing) e.g. 8:53, 9:53, 10:53, 11:53...
- I use 4G/LTE connection only (no DSL)
- Firmware version: V1.0.0.32_1.0.6
- I tried reboot and factory reset
- I tried with both WIFI and Ethernet, I have the issue with both
- I tried with another SIM card (from a different ISP), I have the same issue
- I tried to use the same SIM card on a much cheaper device (Huawei E5573 LTE hotspot, price tag 99EUR vs 300EUR for the Netgear Nighthawk R7100LG). No disconnects.
- I also tried to use the same SIM card on my mobile phone (Samsung s7), I have a good reception (strongest signal) where my router is and I could stay connected 3 hours in a row without any disconnect
Workaround (makes you wanna cry): I rebooted my router at 8:59 to that the interruption is every hour on the dot. Therefore I have less chances to interrupt a remote customer meeting (I/they start sharing screens after the beginning of the meeting and stop sharing before the end)...
Please help out.
That is very frustating and impacts my business (interrupted video conf calls). Downgrading to a 4g travel hotspot is not a professional solution.
I see that similar issues have been reported during the last year. Please advise!
Thanks!
DG from Switzerland
Topic: R7100LG internet connect drops out every hour precisely (interrupts video conf calls, games, stream)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi gbuisson,
Do you have the updated firmware (1.0.0.46) installed?
Blanca
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R7100LG internet connect drops out every hour precisely (interrupts video conf calls, games, ...
Hi Elaine,
I have tried to pre beta FW. Now the internet drop out occurs exactly every 4 hours instead of every hour.
DG
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I suggest that you do a hard reset by following the steps below.
1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
If it didn't work, capture the debug logs for me and send it through PM.
1. login 192.168.1.1/debug.htm
2. click to enable "enable mobile Event log"
3. click "start capture"
4. click "save debug log" -> finished
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello Elaine,
Hard reset does not seem to fix the issue.
I have just started the debug capture.
Thanks,
DG
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you. Feel free to send the logs through PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello Elaine
Here is today's log. I hard reset the router. It restarted at 9:27 CET.
Then I had 3 interruptions 13:27-17:27-21:27. One cut a video conference in the middle
using screen sharing with Skype for business.
I attached the log dump to my case.
Let me also PM it to you. Just in case you need another one I am going to run it again.
Thanks,
DG
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@dam_ged I would like to know that I have forwarded your case to our engineering team to further check on the logs.
I'll provide you an update as soon as I get a response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ant news? On top of what I measured and logged (internet drops out every 4 hours), let me report some random internet slow downs. I had to restart my modem several times. Maybe that was due to logs behind turned on...
Looking forward to your feedback. Does it make sense to return my unit through the warranty? I guess not since I am not the only one in this case (internet hourly dropouts)...
Thanks
DG
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have sent a follow-up email to our engineering team regarding your case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello,
Any update?
Thanks,
DG
PS: can you please add "R7100LG" as a model in the drop down list where we create a community post:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Still waiting for a response from engineering.
By the way, the model number has been added in the list.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, str
Hi
I've the same issues see Case #29210547
I've also tried up-and downgrade fw, hw reset, disable unused functions.... still drops. My mobile hotspot works fine - but I need a router.
I've tried a zyxel lte router from my workplace for a couple of days without any problems! Same location as the netgear R7100lg.
Netgear - please solve the problem.
Steffen
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have sent a follow up email to our engineering team regarding this case.
So far, no word yet but I am hearing that they are coming up with a trial fw.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
no update
still beta and development.
I will write on twitter #**bleep**typroduct to netgear - I think they need a little storm ![]()
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have the same problems here, although I could not swear it happens every hour (I honestly feel sometimes it much more frequent than that but can't really verify). To the point that when I need to download or upload a big file I must use my phone tethered to make sure my connection doesn't drop in the middle. Annoying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Do you have any update? Happy to try a new FW update. If not please advise in case warranty return is the recommended option.
Thanks
DG
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The new firmware is re-introducing the initial issue. ![]()
As I said on 2017-09-22 07:47 PM, beta firmware R7100LG_Q1_1.0.0.33_1.0.6_test was not solving but impoving the issue: internet interruption precisely every 4 hour instead of every hour.
I have just installed the new firmware V1.0.0.34_1.0.6. The issue is back to what it was before: internet interruption precisely every hour.
Interruption every 4 hour was not OK but tolerable pending from a definitive fix. Interruption every hour is very disruptive & not acceptrable.
Please work on the issue with high priority.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yeah, they send me also an FW - doesnt work - its ridiculous. Thats the most **bleep**ed up product i've ever bought.
Netgear - never again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Same problem here, tried last FW version 1.0.0.38, internet connexion still drops every hour.
Strangly, if I ping a remote adress, there is no timeout. So the LTE connexion is still there. But it seems that all TCP / UDP connexions are droped.
Tried 2 sim cards from 2 different providers, makes no difference. LTE signal is good on both case.
Please help.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hey,
The same happens with my R7100LG (firmware V1.0.0.38_1.0.6). All TCP connections seem to be dropped but if I constantly ping some address (like one of the Google's sites), everything seems to be fine.
Thanks,
Sebastian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
We need this to be fixed, it can't be that hard. This is ridiculous.
