NightOwl2
Aug 03, 2024Aspirant
ReadyNAS NVX (RNDX4210)
My ReadyNAS NVX (RNDX4210) no longer could boot up. After power up, the fan rev up in highspeed mode and staying in this mode forever, without going through normal boot up sequence. There's no display on front panel to indicate what's going on. I removed both of my disks and the behave is still the same. I've been trying to do OS Reinstall, following instructions in manual. However, even pressing the recessed reset button at the back while power up, the highspeed fan is still running and there is no display at front panel indicating the boot manual. Could someone please advise on how I could overcome this issue?
- SandsharkSensei
It's most likely a hardware issue, not a firmware one. If it is firmware, USB recovery is what you need, not OS re-install.
But to be honest, your best bet is to replace the NVX. You can choose another (used) ReadyNAS, or we can help you with ways to recover your data from the drives if you choose to go with another brand of NAS. There is a way to use an OS6 based NAS for data recovery, or you could purchase another legacy ReadyNAS running 4.2.x and just move the drives over. For any kind of data recovery, you'll need a place to put the data. Moving to a replacement ReadyNAS will likely make data recovery unnecessary. But when your NAS died, it could have corrupted the volume in the process and recovery will still be needed.
As for what the problem could be, most likely the power supply. But it may be something else. IMHO, it's not worth the cost of a replacement supply to repair an NVX (with it not being able to handle drives >2TB nor be upgraded to OS6) and certainly isn't worth a risk buy of one in case that isn't it.
The NVX can handle > 2 TB drives. But it cannot be upgraded to OS-6.
- NightOwl2AspirantHi Sandshark,Thanks very much for your response!I’m also fairly certain it’s the power supply issue. I couldn’t find any Netgear service manual for replacing PSU, nor details on PSU parts.I’m purchasing an old RNDX4410 from eBay, arriving later this week. From what I can tell, this is a higher end, close variant of my RNDX4210. If it works as advertised, I’m hoping to move my disks over and be able to access my data for recovery.Do you think that would work? Do you see any compatibility issue?I’m also looking for a new solid 2-bay NAS for replacement. The one I have in mind is Asustor Lockerstor 2 Gen2 AS6702T. Do you have any recommendations?Do you have any advice regarding the data transfer (1.5TB) from my existing readyNAS disks to this new NAS?Regards,-- NightOwl2
