- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Vulnerability scan triggers HP printer to print pages
- Mark as New
- Bookmark
- Subscribe
- Permalink
It appears that the Armor vulnerability scan always causes my HP Laser printer to print three pages, containing a client version or similar. E.g. curl and version number or so.
I'm quite sure it's some print service that I'm having enabled in the printer, but does anyone by any chance have a clue what it might be?
It's both annoying and wasting paper that the scan seems to run every week.
And btw the vuln scan come back green and no vulnerabilities detected.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So perhaps this update finally fixed the issue.
Finally. Thanks.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Vulnerability scan triggers HP printer to print pages
Part of the vulnerability checks (not limitet to Armor) is sending some test data to the ports to be tested - if these are printer ports, this can lead to some garbage on the printer paper.
What would you expect as a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Effectively I'd like to know if there are certain settings I could try to turn off from the printer without making printing too difficult, or disable Armor from doing those checks that are causing garbage getting printed.
Anyway, I don't think it's anyone's benefit printing several pages of garbage every week or making printing difficult.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Samsung Multifunctional printer and I also have the same issue occuring. My printer is kept on all the time but goes into a low power mode after not in use for a while.
This has to be something that can be changed in a future firmware or software update. Shouldn't be to difficult to come up with a solution I would think.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also got a contact to Bitdefender support and they at least told me they would look at the matter. Which now reminds me that I've forgotten to give them dumps that they requested.. *sigh*
- Mark as New
- Bookmark
- Subscribe
- Permalink
This also happened to me when I set up my 3-pack Orbi yesterday.
Needless to say, my first concern was if someone had gotten into my network.
If this is going to happen with Armor, how about you say something to that effect ahead of time.
Go ahead and tell your customers, "your printer might print garbage, don't worry, it's fine"
And when you realize how silly that is, you will think, "maybe we should fix the problem"
You have the MAC address, you can easily determine it is a printer.
You can then skip sending traffic to the RTSP port (9100).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @tolidano, as a temporary fix, you can remove the printers from being scanned by Armor. You can do that by logging in to armor.netgear.com and clicking on the router > click on "See all devices on this router" > look for the device/s (printer) that you want to remove > click on the ellipsis (three dots) on the far right > click on Remove.
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter - Unfortunately this fix is too temporary. After a couple of hours the removed printer is automatically restored.
@DexterJB wrote:Hi @tolidano, as a temporary fix, you can remove the printers from being scanned by Armor. You can do that by logging in to armor.netgear.com and clicking on the router > click on "See all devices on this router" > look for the device/s (printer) that you want to remove > click on the ellipsis (three dots) on the far right > click on Remove.
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Also experienced this today on my new RBK23 setup for the first time and initially panicked as I thought I had someone on my network doing a bit of reconnaisance!
Looking forward to that fix 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
this is waisting my printer ink & paper!
any updates on netgear fixing this?!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a couple of LIFX bulbs too and thankfully haven't had that issue! Trial expired so will now remain deactivated. Might give it a go another day if they sort the printing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been having the same issue. Came back from a trip to a small stack of paper in my printer. Is the hotfix firmware available? Or it this issue solved in RBR50 firmware version 2.5.1.8?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all, this has been reported to engineering and is currently being worked on. We will provide an update once available.
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there an ETA by when this issue will be resolved? I have been having the same issue since I enabled Netgear armor security.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not holding my breath on this and tbh not that bothered anymore, I have not renewed subscription as a result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please fix this ASAP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look at the start date of this thread and others like it. Clearly not a high priority for Netgear to fix. I didn't bother subscribing after trial and didn't see much value in the service anyway. If you're interested in this sort of thing and have the time/skills look at running openvas on docker on your network.
