Orbi WiFi 7 RBE973
Reply
Allow certain apps unlimited time
Rogellis
Follower
Is there a way in Smart Parental Controls to allow certain apps (like a music app) unlimited time?  I'm only seeing a small list of apps or categories.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Allow certain apps unlimited time
Hello Rogellis,
The Smart Parental Control feature should support this. What music app are you referring to?
Christian
Message 2 of 3
svetaketu
Luminary
Hi @Rogellis,
Try this out.
  1. Use the music app
  2. Wait for about 5mins for it to register in the history
  3. Check the History tab, under Visited look for the URL that the music app is directing to.
  4. Once you've located the URL, tap the 3 dots on the right side.
  5. Select Set as Unlimited, Save
  6. Now go to the Site Manager tab, under Unlimited, you should see the URL listed.
  7. Test. If it doesn't work, try to locate the correct URL and repeat the steps.
Hope this helps.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2025 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
