Orbi WiFi 7 RBE973
Reply
Parental Control for Orbi RBR350
h1effe
Can someone please tell me how to do parental control to this model if there is?
I am using Orbi iOS app. (2.42.0.56). Firmware version: v4.20.0.4_3.100.71
Message 1 of 2
KevinLiT
NETGEAR Moderator
Re: Parental Control for Orbi RBR350
Hello @h1effe ,
Welcome to the NETGEAR Community!
I understand that you would like to start a SPC subscription using your RBR350.
To set up and install NETGEAR Smart Parental Controls:
1. Launch the Orbi app or Nighthawk app.
2. Tap the Parental Controls tile.
3. Tap Add New Profile > Set Up.
We recommend setting up a profile for each child whose Internet activity you are monitoring.
4. Enter a name for the profile you are setting up.
5. (Optional) Select a profile you are setting up.
6. Tap Continue.
7. Select the devices that your child can use to access the Internet.
For example, if you want your child to only be able to access the Internet on your iPad, select your iPad from the list.
8. Tap Continue.
9. Tap START 30 DAY FREE TRIAL.
If you have completed the free trail please follow the steps below to start a paid subscription:
Launch the Nighthawk or Orbi app.
The SPC dashboard displays.
Tap the "Your trial is expiring" banner at the top of your screen.
Tap See Pricing.
Choose a subscription plan.
Tap Get Started.
Fill in the required payment information.
Tap Place Your Order.
Best,
Kevin
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 324 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
