- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Parental Control stopped working
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Parent Control subscription for about a month. It's been working fine. But today it stopped working. It doesn't show usage History and doesn't limit the usage.
The firmware version is 2.7.3.22.
What shall I do? Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
(For some reason all the other related topics have been marked as closed)
Netgear Support finally resolved the issue I had with SPC not working following the force migration in January 2022. Basically, it would work for a few hours and then stop applying rules, logging history, etc. It was resolved end of October.
The problem was caused by Circle settings not allowing Netgear SPC to work. Level 3 support recreated by setup in their lab and built a script that deleted all trace of Circle.
After running this script into the router, I did factory reset and reinstalled the app. The profiles weren’t lost and SPC has been working for 2 weeks non stop now.
So if you are a previous Circle user on Orbi and could never make SPC work, they have a solution. Just need to point them to Level 3 script they have built. (PM me for my case number)
Thank you to Bernard for Level 2 who finally got this resolved.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parental Control stopped working
Have you tried a simple reboot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, power-cycled many times.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What device(s) have you installed Orbi app and Circle on? Try a different device to compare results?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm using Comcast (business) Internet. The modem model is Cisco DPC3008.
I installed the Orbi app on my android phone.
I haven't tried factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I called tech support, and was told to do a reset. Afterwards, parental control works again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Happy it was the easy of a fix.
If you mark your solution as solved, it might help the next person with that problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
dd-walker, it will fail again.
Join the club of the factory resetters that make it work for 2-3 days and then it will stop working again. They have no clue what is the root cause. I have a case opened with Netgear on the same version and hardware and in the mean time, paying for a subscription on a product that shows no history, no usage, no filters. I didnt the whole factory reset, reinstall app, redo configs many many times and it always end up failing after a few days. This product is not working. Too bad they forced us to go away from Circle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is SPC still working for you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
3 times in one month I had to do the factory reset, install config, reinstall app, rebuild profile. It only bought me 2-3 days of working SPC before it fails again and stops tracking usage or applying filters. I stopped wasting my time and ask Netgear to find a fix ASAP. Case is still open. Circle worked more than a year with zero interruption. SPC from Netgear is broken.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have a case open with NG support then keep in contact with them until the problem is resolves as theres nothing else we can help you with here in the forums.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had success turning parental control off and then back on at the settings page.
The cloud icon on upper left corner takes you to a menu:
Settings>Parental Control>enable Smart Parental Control: off then wait a while and then on again.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parental Control stopped working (SPC fail after Circle migration)
Thanks for letting us know the details and glad there seems to be a solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't get netgear, orbi or armour to stop anything through parental controls or otherwise, can you share your solution with me?
thanks,
Pat
Maninarena@yahoo.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please message me your case number they cannot fix my issue i have a stuck profile that cannot be deleted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been facing the same issue and Netgear support has been sitting on this issue since Dec 19th! Could you please share your case number which helped resolve the issue. Much appreciated and thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can someone send me the file?
