- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow wireless connections RBR750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I own an RBR750 with an RBS750 satellite, and my connection is 1Gbps. However, I can only achieve this speed with a wired connection.
With wireless connections, I can reach a maximum of 600Mbps. This happens on the RBR, and it's even worse when I'm connected to the RBS.
Is there any configuration that can help me achieve a higher wireless speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow wireless connections RBR750
A maximum PHY speed is 1200 Mb/s for an 80 MHz channel using a 2×2 client, leading to ideal 840 Mb/s throughput. On a realistic distance to the router or to the satellite, you can expect a PHY speed of 864 Mb/s, leading to 600 Mb/s throughput. Does not sound wrong to me.
The RBS750 satellite is supposed to connect on the 5 GHz backhaul, again on 80 MHz channel bandwidth, but these are 4x4 devices. Under good conditions, this wireless backhaul can reliably take both possible access point radios (the 5 GHz and the 2.4 GHz) front haul. It's worth to review the backhaul status, and potentially relocate the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm testing with an iPhone 14 Pro and a notebook, and I have the same performance on both.
I'm thinking about doing a factory reset, but before I do that, I would like to know if there's any configuration I'm forgetting.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
