iau's avatar
iau
Ability to use 3TB disks on ReadyNas Duo
Hi,
I have a ReadyNas Duo with 2TB that are quickly filling up. I have been hoping that it would be possible to use 3TB disks when they get more common, but it doesn't seem so. Is the problem with compability connected to the hardware itself or is it a firmware thing? I have been very happy with my Duo, but are very reluctant to go for an other ReadyNas with larger capacity in case it will also be a dead end regarding firmware updates or whatever it takes to be able to upgrade disks after a while.
Keep checking back every other week or so, but the compability list doesn't grow. Will it ever?
Hoping for some good solutions here...
-iau
ProSupport for Business
