- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DNS connection via X10 Nighthawk R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I am trying to get my laptop on the wifi , it can see the internet but the Router does not allowcate the connection. When plugged into the ethernet (hard wired) I have a perfect connection and access but via WIFI nada.
Please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DNS connection via X10 Nighthawk R9000
@Toxicfox wrote:
Hi there,
What do you see that suggests that it is the router that "does not allowcate the connection".
(Is allowcate supposed to be allow or allocate?)
Does anything else connect to the wifi?
Are the wifi LEDs showing on the router?
What messages do you see when you try to connect the laptop to the wifi?
Are you sure that the laptop isn't blocking the network? This can happen when Windows sees a new network and tries to protect you from connecting to a "Public" network.
There is a manual for the R9000 somewhere at the end of this link:
>>>> Nighthawk X10 R9000 | AD7200 Smart WiFi Router| NETGEAR Support <<<<
By the way, you have posted your message in the section of this community given over to Apps and Services. (This is easily done, given Netgear's impenetrable community structure.) Your device is a Nighthawk WiFi Router.
You might get better replies, and find other answers, over in the appropriate section:
Nighthawk WiFi Routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
It should read allocate, sorry, all other PC's/Laptops/phones go through, just this one ACER laptop doesn't.. All light are on the router and working properly. I shall review the manual and find out more. If it still persists I shall inform you all.
\Regards
Walther
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds more like an issue on the laptop.
I'd check Windows with the Network troubleshooter.
User | Count |
5 | |
4 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
