- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Genie 2.4.22 (IOS) only displays first 5GHz radio when accessing wireless settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Genie 2.4.22 (IOS) only displays first 5GHz radio when accessing wireless settings. I have two R8000s set up as access points, and they both exhibit the same issue. Firmware on R8000 at 1.0.2.46.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Genie 2.4.22 (IOS) only displays first 5GHz radio when accessing wireless settings
Do you maybe have the Smart Connect option enabled? If not what wireless channels do you have set for the two 5GHz radios?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
With Smart Connect enabled both 5GHz radios use the same SSID, so that may be the reason for the single listing in Genie. If you scan for wireless networks using a different application or device do you then see two 5GHz APs with the same SSID?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes If I scan the network with other software (e.g. inSSIDer or iPhone Airport software) I do see each 5G network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I would suggest that Genie is just using a bit of insider knowledge to display the two Smart Connect 5GHz channels as a single entity.
