- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk app login problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey there, so i downloaded nighthawk app for my android 7 smaphone,
Configured it, and it has login issue, after i entered my password, i wont be able to login second time, no matter what i did, it will always say: "Logon time out, try again. if this issues persists, try rebooting your device". After i entered my password, i wont be able to login second time, no matter what i did, it will always say: "Logon time out, try again. if this issues persists, try rebooting your device". i tried to clean the coockies and what no, wont work, nada, i dont have that issue in web login.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk app login problem
I assume that you duplicated the text of your message. It seems a bit repetitive.
I can't see what you image is showing as a login target.
There are three possible steps involved in getting into with the Nighthawk app:
- Connect to the wifi form your (unnamed) Netgear device
- Connect to the router's controls
The third option depends on whether you are on local wifi or using Anywhere Access.
Each option has a different password.
- the wifi connection
- the router interface
- Anywhere Access
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue as you. Based on the number of times this issue is in the forum, this app/product is junkware. Looks like everyone will recommend factory reset.
