- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk application stopped working on iPhone and iPad, HELP
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been using the latest version of The nighthawk application on my iPhone and iPad, iOS 14.3. Recently the application no longer retains my password and when I can get the application to try to connect to the router in response the applicates advises that I am not on Wi-Fi or did it not detect the router. The devices are clearly on Wi-Fi through the Router and the router is clearly operational. Any assistance would be greatly appreciated thank you
Larry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk application stopped working on iPhone and iPad, HELP
@larryis1 wrote:
I have been using the latest version of The nighthawk application on my iPhone and iPad, iOS 14.3. Recently the application no longer retains my password ..
Which password? Wifi? Router? Anywhere Access?
What are you trying to do?
There have been recent issues with the Nighthawk App and iOS. Maybe Netgear is trying to keep up with Apple's never ending attempts to make life interesting for users.
- Mark as New
- Bookmark
- Subscribe
- Permalink
trying to use application in the manner it was intended. Access connected device list and run speed test at router input from modem. I know i can also domthis from router URL on browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know of two "intended" ways.
Wifi connected and into the router. Or Anywhere Access and into the router.
They are different.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router is connected to my Cox panoramic Wi-Fi modem, my computers are connected to the router through ethernet all other devices use the router as Wi-Fi signal. I am not using anywhere access this is strictly occurring while at home on the local area network, no remote access is being attempted. Problem is I can't even log on to the router through the Wi-Fi network using a night Hawk. I can't get to the router directly through a browser URL connection without any problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@larryis1 wrote:
My router is connected to my Cox panoramic Wi-Fi modem....
That's a big alarm signal.
A wifi modem is almost certainly a router. (It has to be to manage the wifi bit.) This means that you may well have two routers in a row. That's a bad idea.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
This arrangement could well explain what you see. Your apps expect to be able to get into the Netgear device using the usual address conversion. You have complicated the issue by using two routers that can mess up those addresses.
Tell people the exact details of that "Cox panoramic Wi-Fi modem" and you might get more detailed, and informed, advice and possible solutions.
If this is what you have:
Cox Panoramic WiFi Gateway Router | Cox Communications
then you need to fix the Double NAT issue before your apps can do their stuff. The first option would be to put the Cox thing into "bridge" (modem only) mode or to put the R7900P into wireless access point mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Cox panoramic MODEM is in BRIDGE mode, it is NOT using the router feature at all. The router feature of the modem is DISABLED. The NETGEAR router is connected directly to the modem, the NETGEAR router performs ALL distribution functions for direct ethernet connections as well as Wi-Fi signal distribution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem latest version of app on IOS is unable to communicate with the router. Fails to get device list, router specifics, even unable to reboot router. Router is functional however as we have been using for several days. Seems latest app is flawed. Even signing it,the app does not remember me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Tucson_Jim wrote:Same problem latest version of app on IOS is unable to communicate with the router. Fails to get device list, router specifics, even unable to reboot router. Router is functional however as we have been using for several days. Seems latest app is flawed. Even signing it,the app does not remember me.
It is sad that Netgear keeps on putting out applications that are defective and causing their users to have to install uninstall reinstall and continue to try where the application has zero chance of working. Netgear should test its applications thoroughly before releasing. I personally have wasted way too much time trying to use this poorly designed and ineffective application.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@larryis1 wrote:
It is sad that Netgear keeps on putting out applications that are defective ....
In this case, Netgear did not put out a defective application. Apple made changes that broke the thing.
Netgear's crime is not having a clear enough crystal ball to know what Apple would do and not responding quickly enough. But that too may be down to Apple, which is famous for giving other brands a hard time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I can agree with the Apple comment. However it is unsettling when these situations occur,especially immediately (in my case) following a firmware update. It would be beneficial to the community if some notice of this situation was made as we are now so dependent on these devices. My immediate thought was that my router was no longer functioning as it should and I startled thinking of alternatives (and other devices to replace it), especially when rebooting the router failed to clear this up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also having the same issue, I get to where it asks for admin password and just "spins" and does nothing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can confirm its not an iOS 14 problem. I also installed on an iPhone with 12.1.5 and get the same errors I get in iOS 14, I thinks its a Netgear firmware issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting since we just had a firmware update. Wish the netgear folks would chime in and help us out here. I have invested a lot in netgear HW, modems & routers, would hate to lose faith now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I thought that was the case, as Nighthawk worked just fine before the last firmware update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Nighthawk App users,
For us to to look into this further, may you provide the following info:
Router Model:
Router Firmware Version:
Nighthawk App Version: (please also specify if it's iOS or Android)
Local Network Access enabled: Yes/No (iOS only)
Rebooted Router: Yes/No
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router Model: X6 R7900P
Router Firmware Version: cannot access, but latest from several days ago
Nighthawk App Version: (please also specify if it's iOS or Android) IOS 2.7.6.3
Local Network Access enabled: Yes/No (iOS only) yes
Rebooted Router: Yes/No YES
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Christian_R wrote:Hello Nighthawk App users,
Router Model: R7960P
Router Firmware Version: 1.4.1.68_1.3.28
Nighthawk App Version: (please also specify if it's iOS or Android): iOS version 2.8.0.15
Local Network Access enabled: Yes/No (iOS only): YES
Rebooted Router: Yes/No: YES
Thank you Christian for your engagement. The data requested has been provided, see fill ins above. Please advise.
Thanks, Larry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Christian,
The requested data has been provided within this thread. What is needed is a sustained solution as this Nighthawk app disconnect happens periodically with router firmware changes. The app fix and/or firmware updates need to be sustained so it is not susceptible to firmware changes, otherwise Netgear Nighthawk customer/users are destined to repeat this problem over and over again. Please confer with your firmware development team so that their update efforts fully take into consideration sustained/uninterrupted connectivity with Nighthawk each time the firmware is updated and/or the app is updated. Otherwise the user community experience will continue to be undesirable with Nighthawk. Users should not be expected to restart routers everytime the Nighthawk app is unpdated. The connectivity between the app and the router over the LAN should be seamless and uninterrupted when changes occur.
Thanks you for your engagement and consideration.
Best regards,
Larry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Tucson_Jim, frechcamp49er, & larryis1,
Thank you for getting back with the requested information. Our engineering teams are aware of the reports and currently investigating. I'll provide an update to the thread as soon as I can.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, thanks Christian , please remember that we are unable to communicate with our router with IOS, not even able to sign in as Admin, so any solution needs to take this into account. Not sure if you can "push" a solution through or maybe a memory stick update will work. If we need to reset to factory settings, this is difficult & stressful, so providing very detailed instructions is essential. BTW, neither the Genie nor Nighthawk apps work. Since my daughter has come here and is working from home, I have been reluctant to do anything to interfere with the router. On the weekend, I can try to communicate with it via my MACBook.
thanks
Jim
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is one way into a device from Android apps that should work with iOS. Forget the app, think of the phone as a PC.
Connect to the wifi. Aim a browser at the URL for the router and then fill in the usual username and password.
You may have to kick aside any security warnings from whatever browser you are on. (I just hit that in Chrome on an Android.) Apple may have disabled that sort of thing, which would rule out this wheeze, but there is no hard in trying.
It will probably look like a mess, but it might allow you to get at crucial controls.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
