- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6220 not conneting with Nighthawk
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
My R6220 used to connect perfectly on Genie App on iOS (latest OS and app versionà.
I have upgraded to Nighthawk App and it can not connect: it says: "Logon timed out, please try again. If this persists, try rebooting your device."
I have rebooted / restarted and same still issue.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6220 not conneting with Nighthawk
Supposedly the app is compatible with that router.
https://kb.netgear.com/000055505/Which-products-support-the-NETGEAR-Nighthawk-app
With that said, have you tried uninstalling the app and reinstalling it? Restart the phone after the uninstall.
You put you're on the most most current version. What is it? A number helps for others who have this issue.
Same with your version of ios. What phone version and ios version are you on?
You can also use your broswer to control the router. its not as slick as the app navigation but at least you can still control the app until whatever is causing the issue is resolved. I've had issues with the app before so I tend to just control it with the browser gui. Not ideal for those that like the app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I have latest version everywhere (router firmware, ios, app)
The access through browser works fine with the IP but I want the mobile app to work.
What else could I explore?
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you try uninstalling, restarting the phone, and reinstalling the app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes - multiple times on both my iPhone and iPad.
In the R6220, I see nothing in the logs when I tried to login
- Mark as New
- Bookmark
- Subscribe
- Permalink
what version of IOS are you using? Device model?
- Mark as New
- Bookmark
- Subscribe
- Permalink
iPhone 8 plus
iPad Pro 10.5
iOS version on both device:12.4.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest available:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Current version of the app is 2.4.3.1
if your phone and tablet are on this version and you uninstalled and reinstalled. I'd try reinstalling the firmware to your router, factory resetting it, and reinstalling it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router works well and I don't want to loose all my configuration.
It is in AP mode and both 2.4 and 5 bands are using the same SSID.
Can you try to reproduce my issue ? I have already lost too much time because of Netgear not supporting anymore Genie app.
I am about to buy a new second router and I am very dissapoined if Netgear is introducing so big regression in their product.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's one for example.
https://community.netgear.com/t5/Nighthawk-App/R6120-Access-Point-setup-and-Nighthawk-app/td-p/17635...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure to understand because the Genie app was perfectly working in AP mode without remote management checked.
So it is a major regression for me as you are not allowing me to use Genie anymore . Can you please confirm with your product manager it is a bug and when it can be fixed? Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can always contact support but they charge if you're after the 90 days of free support. thats why there's the community forums. To try to help out people past that 90 days.
to contact support you go to mynetgear at the top, register an account, and then register a device. From there you can contact support.
One thing you can try to do, since the R6220 is in AP mode, you could try resetting its lan address to one on the same subnet as your primary router/combo device. So if your combo device is on 192.168.1.1, you could change the address of the R6220 to something like 192.168.1.100.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In reality, Netgear itself does not provide paid for support. It farms that out to GearHead Technical Support.
As @plemans says Netgear's support is limited to 90 days. You get that by registering your device and starting the process on the MyNetgear site.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
