× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
BUG: Qos stopped detecting CSGO - XR500 V2.3.2.66
Retired_Member
Not applicable
Qos Stopped detecting CSGO while i was playing a few days ago
What ive tried
- rebooting router
- removing and adding source/csgo to qos
- enabling All Devices DumaOS Classified Games.
- resetting router to factory settings
- downgrading router to 2.3.2.66 from 2.3.2.104
- resetting router to factory settings again
- cmd ipconfig to confirm ip, changing device name in router, adding csgo to qos
- formatting pc
- manually adding csgo ports, cant overlapping streams, maybe im doing it wrong
Steam Support Article
other games show High Priority Traffic Detected like PUBG
other source games show High Priority Traffic Detected like TF2
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 6
Accepted Solutions
Retired_Member
Not applicable
Re: BUG: Qos stopped detecting CSGO - XR500 V2.3.2.66
I appreciate the days of replys, I finally got it working, here is the steps to get it fixed.
Reset Router to Factory Settings:
Settings - Administration - Backup Settings - Erase
Manually Update Firmware - download
Settings - Administration - Firmware Update - Browse
     tested on firmware - XR500-V2.3.2.56.img
          updated to - XR500-V2.3.2.66 - added QOS still works
Add Advanced QOS
Source Port
Start 1, End 65535
Destination Port
Start 27000, End 27100
Protocol, TCP & UDP
Message 5 of 6
All Replies
Netduma-Fraser
NetDuma Partner
Likely that we need to update the service, how did you specifically add the ports manually? What are the rules you made?
Message 2 of 6
Retired_Member
Not applicable
when manually adding ports i tried
Source Port
Start 1, End 65535
Destination Port
Protocol, UDP
Source Port
Destination Port
Protocol, UDP
Source Port
Start 27020, End 27039
Destination Port
Protocol, UDP
Source Port
Start 27015, End 27015
Destination Port
Protocol, UDP
with many variation of these numbers and protocol
based on the Steam Client ports shown
  • UDP remote port 27000--27100: Game traffic
  • UDP local port 27015 (default): gameplay traffic
 this netduma article to help-classify-games-for-traffic-prioritization
 but it shows source as IPv4 Address so i dont fully understand this tutorial yet
Message 3 of 6
Netduma-Fraser
NetDuma Partner
You had the right idea with the first rule but change it to TCP/UDP as you're missing those and they are needed. Also add one rule along the same lines as the first so source the same but destination 4380 UDP. Then remove the other rules and see if it works.
Message 4 of 6
Retired_Member
Not applicable
Add Advanced QOS
Source Port
Start 1, End 65535
Destination Port
Protocol, TCP & UDP
Message 5 of 6
Netduma-Fraser
NetDuma Partner
Glad you got it working and thanks for the update with the solution.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3022 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
