- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Feature request for Hybrid VPN DUMA OS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: Feature request for Hybrid VPN DUMA OS
High, yes it's highly possible. Most of the cases are when I'm not using any device at all or when I'm using the device which is not on the vpn traffic list.
Anyhow something strange was happend when I tried add that inactive param. I was not able to connect with VPN at all. I've restored config to the origianl one but following error always appeared:
openvpn-event.lua: Exec 'ip route add default via '10.8.1.1' table 1' failed with 2 Thu Apr 29 07:17:50 2021 WARNING: Failed running command (--up/--down): external program exited with error status: 3 Thu Apr 29 07:17:50 2021 Exiting due to fatal error
After router restart, I had similar issue. 2nd restart of router fixed that issue, and I was able to connect and additional param was added. I'll inform in any changes.
Additional question:
Do you know why this error appears?
Tue Dec 29 09:41:36 2020 WARNING: --ping should normally be used with --ping-restart or --ping-exit
In config ping and ping-restart specified:
ping 15
ping-restart 0
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not entirely sure why as you're using ping-restart after it, but it looks to be just a warning, is it causing any issues or are you just curious as to why you're seeing it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm only curious why it's in the logs because it's properly defined, isn't it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a whole week of working VPN correctly, I was thought that we resolved that issue. Yesterday the exception was thrown again, and VPN connection stuck in a failure state again, but somehow I was able to use internet, when "block traffic if VPN disconnect" was set.
openvpn-event.lua: bad argument #3 to 'format' (string expected, got nil) -> stack traceback: ?: in function <?:73> [C]: in function 'format' ?: in function 'safe_execute' ?: in function '?' ?: in function 'on_vpn_down' ?: in function '?' ?: in function '?' ?: in function '?' ?: in function <?:48> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:46> [C]: in function 'run' ?: in function <?:345> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:261> (tail call): ? /dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> [C]: in function 'xpcall' /dumaos/api/cli.lua:59: in main chunk [C]: ? Thu May 6 15:06:50 2021 WARNING: Failed running command (--up/--down): external program exited with error status: 3
As I expected, with connection mode to 'Always on' and VPN setting inactive 0, we reduced the chance to get an exception by losing connection, but we didn't found the cause of that issue. Thanks for both suggestions, so far I'm happy with them. If still, you have any idea how to fix it, or I can help you somehow find the cause let me know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does "--connect-retry n" retry the VPN connection using the saved OpenVPN file in the Router, or does it just send a request to the same IP VPN server to try and reconnect? What does "inactive 0" do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
