× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Latest FW XR500 V2.3.2.114 but no Ping Heatmap
Ruubster1989
Hi,
I have the xr500 since this week. I have the latest firmware update on it. XR500 V2.3.2.114. but don't have a ping heatmap. How is this possible? See picture.
Thanks for the help.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: Latest FW XR500 V2.3.2.114 but no Ping Heatmap
There is a DumaOS 2.0 update of the same name, here is the link to the 3.0 .114 update - https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0 - I would recommend you do a factory reset once upgraded.
Message 2 of 4
All Replies
Netduma-Fraser
NetDuma Partner
Message 2 of 4
Ruubster1989
Have I lost all data? after a factory reset?
How do I do a factory reset?
Thank you!
Message 3 of 4
Netduma-Fraser
NetDuma Partner
You would have to setup from scratch after a factory reset yes. You can do that from Settings > Administration > Backup Settings > Erase on the interface.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3309 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
