- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Latest firmware download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latest firmware download
@iielmesswavy what VPN provider were you using?
@Anton774 does server that you’re adding have the exact same ID everytime or a different ID?
@Knightkast no news but it won’t be too long.
- Mark as New
- Bookmark
- Subscribe
- Permalink
diffrent ID all 14 of them so far but same location. @Netduma-Fraser
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser i am using ExpressVPN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@iielmesswavy could you provide the config file you're using please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
fraser i am surely not try to argue with anyone im saying geo filter used to be releventyou actually could block servers by being in strict mode and leaving filter off. and it would give you a server in circle but players outside the circle could still join. not with filter off it cuts off strict mode also. meaning it connects you to any server. and now the geo filter is hard pressed to find servers in my area hell even on my coast.and i know where the servers are at and it does not want to connect to any of the close servers it wants to put me in servers where the ping is 50 plus. and fraser the router will test 900 plus up and down when i reformat the router and it connects to internet but if irun auto config it only wants to give me 500 or lower on download speed and 700 or lower on upload speed. and then the benchmak test does not take into fact for the cc and upload speed is just uncontrolable. no mater where i put the sliders. i have to go and set bandwith and use it as a slider. and even then the out come is still sketchy on upload speed, and when i try to play agame its the absolute worst hit detection and i get frame killed. its like im using whole clips to kill one person and they just turn around and look at me and i fall over dead, but kill cam shows they hitting me with half a clip. now are you saying not to use dsl reports or not to use tp
- Mark as New
- Bookmark
- Subscribe
- Permalink
and yeah the router supports gig speed but it seems to try to divide the bandwidth to have a gig up and down instaed of gig up gig down, if the download speed is at 400 it only goes up to 700 on upload if upload is at 80-0 the downlo9ad only wants to go to 250. its never 900 to 900. its always divided to get around 1200mbs combined.and heres what happens. it gives me the 800 plus upload but only 250 t0 450 download and at the same time it makes upload speed sparatic meaning its got the speed but it has serious buffer issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
helo guys
sry, whats the latest beta firmware to xr500?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When is a new beta coming out?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will the firmware update become available this week @Netduma-Fraser ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, I noticed another issue.
I have bought another router (Netgear ax12 wifi 6) still using modem cm1100.
I have connected my Xr500 and disable DHCP Server and use one of LAN Ports to connect between the two routers. The reason I wanted to this is 1. Upgrading to the new generation of WiFi 2. Dedicating the xr500 strictly towards gaming. But I notice that it took a lot of the features away and don't know if this is the reason why its affecting the the vpn. Please advised if i did wrong or better way to set this up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, So would I keep the connect between two router on LAN and just add DMZ. Furthermore, Changing the third value of the IP address manually in xr500. If not please tell the specific instructions on what I need to do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem > AX (DHCP enabled) > XR (DHCP enabled)
Take the WAN IP from the XR System Information page and put that in the DMZ on the AX and everything will work correctly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ax12>xr1500
will the internet from lan ax12 be connected to xr500 lan or wan?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
okay, done that and setup dmz server on the ax router like you stated. Now, I run into the issue where I can't see my local media server but the features are back on the xr500. Furthermore, it seems that my xbox NAT is showing strict because of double NAT.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the media server- I have a 4tb connected to the ax 12 sharing storage to any device. I'm using Readyshare. When xr500 is connect via lan instead of wan the storage shows on Xbox. Also, I'm opening NAT on xr500 to see if it works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have now opened nat on xr500 but its still showing as stricted with double nat.
- Mark as New
- Bookmark
- Subscribe
- Permalink
