- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Latest firmware download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: Latest firmware download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latest firmware download
你这个是xr450固件 我的是xr500也能使用吗
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is anybody else having on and off issues with the 5ghz band on the XR500? I'm not using smart connect, and have the 2.4 and 5ghz bands named differently. Sometimes I'll be able to connect to the 5ghz band, and sometimes it gives me the "Unable to connect" message. Contemplating doing a factory reset with 3.0, but would like some thoughts first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same wireless setup as you and i've been getting the same issues of random devices not being able to connect via wired or wireless. It's beyond frustrating when a router of this caliber can't seem to provide the basic function of it's existence which is to simply connect your devices to your ISP. I have noticed when a device tries to connect to the wifi i get this error in my monitor log. [dumaos] error parsing line in arp table [mac address of device] . if you look in your logs you are probably seeing the same thing. a number of people have posted this same message in their logs too on this thread.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@zmon @ZeroNero use a WiFi analyzer to find the least congested channel for 5GHz and change to that. Keep in mind also that 5GHz has more difficulty penetrating walls than 2.4GHz does so the further you are from the router the weaker the signal will get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
我点击链接还是无法连接下载 不能发固件包吗
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fraser,
I should note that I'm usually next to the router when it says this. My router's logs are full of error parsing line in ARP table if that matters at all. May go forward with the factory reset with a fresh install of 3.0.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm usually really close to my router too and it has happened on both 2.4 and 5ghz and on wired devices randomly but i will check congestion with a wifi analyzer just in case but I don't think that's it. Also, i have done a fresh reset on the latest .56 firmware and multiple times since testing out duma 3.0 beta but still the issue persists. I may drop back down to .32. I think this was more stable when i tried it before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Initially mine was disabled but i read on this thread or another (can't remember at this point) that enabling it might help my issue and it did work to get one device connected to wifi (my cell phone) but then my amazon cloud cam went offline so I disabled it again. One thing i did do that seemed to help at first was go to device manager and remove all devices that were offline and reboot the router. Most of my devices came back up and are still up but then last night my nvidia shield had issues connecting to 5ghz again. had to fire up my verizon mifi just to watch the vp debate 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's a shame that it's been pushed back another week, these QoS/IPv6/5ghz WiFi bugs are almost rendering the router useless at the moment.
Why do you need Netgear to release it? It's a public BETA, so surely you guys can push it out without them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear are the producer of the hardware (XR500) so it is down to them to provide the images etc and make sure drivers etc are correct for the hardware.
NetDuma just provide software ontop of Netgears hardware esentially on the XR series routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep fully get that.
Firmware isn't the issue.
Issues are with the RAPP's that are provided by Netduma, so surely they can use the existing firmware with updated DumaOS beta files, thus really needing Netgear to compile a new firmware with their bits so to speak.
Just seems like a backwards way of doing things in this day and age.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Shame it wasn't done at the design stage to have the OS and firmware seperately so that you could update the OS at your own pace and then work with Netgear when they wanted to do a firmware upgrade to make sure it didn't break anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It will depend if any of the existing features we see/test now will be an Rapp after the Beta or stay how it is currently (I assume the later).
I think the current features rely on the features of the router OS itself rather than being addons which could explain why they are embedded into the firmware/image rather than just addons/Rapps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a dumaos 3.0 beta for the xr700?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Jayappa not yet, NG devs are on a holiday at the moment but once they're back they will build a version, go through preliminary testing and I think it will be out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
How would i go about reverting to the version prior to the 3.0 update? Ever since I updated my router has been disconnecting internet and I have to unplug multpile times a day. I appreciate nay help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the pre beta version, you downgrade the same way you upgrade. Would suggest doing a factory reset on the beta first if you haven't done one. https://kb.netgear.com/000061157/XR500-Firmware-Version-2-3-2-56
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much. I haven't done a factory reset on the 3.0 so ill do that first. I'll update to how it goes! Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've noticed only two annoyances so far with version 2.3.2.104.
- WAN connection suddenly drops, but ultimately requires a reboot.
- Voice over WiFi (mobile calls made via the iPhone when connected to WiFi), will suddenly cut out.
Other than that, it has been more stable than previous interations.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello
I woulds like to download the beta 3.0 is it available at the moment. if yes were can i download it pleas . asb gaming thanks
