× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 Not adjusting to daylight saving time
Jamstaaa
Apprentice
I'm on the latest beta firmware .120 and it seems the router isnt updating its time correctly with BST. The clocks went forward last Sunday (28th) but my router is still showing the time as one hour behind even though under Advanced > Time Zone the 'Automatically adjust for daylight savings time' is ticked.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Liam
NetDuma Partner
Re: XR500 Not adjusting to daylight saving time
Thanks for flagging this up with us!
If you change time zone, then switch back to GMT with the box ticked, does it update to the correct time?
Message 2 of 4
Jamstaaa
Apprentice
@Netduma-Liam
No it doesnt. I figured out that the changes to settings in the top right menu dont affect those in the actual settings area on the router.
So e.g. Three dots in the top right > Advanced > Time zone if I change the DST setting here it doesnt do anything.
However if I go to Settings > Administration > NTP Settings and change it here too then the time updates correctly. It seems these setting areas need to work together or one of them be removed.
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Great well done for sorting it out, we'll take a look
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1077 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
