×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
such a question
Raf1212
Apprentice
such a question
I was interested in a certain thing, as I mentioned earlier, I now have 2gb internet shared by 1gb ports, and as xr500 connects to one port, and another computer that does not want to use duma os to the other port, whether it will work, will there be problems with upnp and another,I was interested in a certain thing, ,  I know that some time has passed and the man has enough waiting, but he would like to give a chance to xr500, but does it make sense
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: such a question
Correct, there won't be any issues in that configuration
Message 4 of 4
All Replies
Netduma-Fraser
NetDuma Partner
Re: such a question
Just to clarify, you have your ISP modem/router that supports 2Gbps with 1Gbps LAN ports, the XR500 is connected to one and the PC connected to another? If so then the ISP modem/router with UPnP enabled won't have any issues determining where to send traffic.
Message 2 of 4
Raf1212
Apprentice
Re: such a question
@Netduma-Fraser yes, I wanted to do this because my son does not want the dumaos of wasps and he wants all the speed, but will upnp xr500 with upnp isp enabled will not cause problems, and I understand that the rest of the devices are to be connected to xr500
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Re: such a question
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1263 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
