× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A problem with dumaos
BowlOfHygieia
Follower
Hi
I recently bought the XR300 and did all the setup includin geo filter, but when i changed the geo filter settings and rebooted the router I got this message whenever I enter the dumaos on my router :
You are no longer connected to your router. If your router is rebooting then keep this page open as it will automatically reconnect to the router's interface when the reboot is complete. Otherwise please check your connection e.g. you are connected to the correct router.
Any solutions ?
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma_Alex
NetDuma Partner
Re: A problem with dumaos
Could you try accessing the router via a different method? For example, if you were using routerlogin.net, you could try using 192.168.1.1
Message 2 of 2
Discussion stats
  • 1 reply
  • 1045 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
