× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Acheter un r7000
Hunter_NX
Acheter un r7000
J'aimerais acheter un routeur r7000 mais je voudrais savoir si celui ci permettera de diminuer les pertes de paquets ?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 8
Guru
Re: Acheter un r7000
en anglais s'il vous plaît
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
Message 2 of 8
Hunter_NX
Sorry i thought i was in a french forum.
Do you think the r7000 will resolve my loss packet problem
Message 3 of 8
Guru
Packet loss can be anywhere, ISP services, Modem, router, WiFi, Cabling or PC.
Use pingplotter.com program to check for packet loss between PC and ISP services. Test with PC directly connected to modem, then again with a router connected.
Message 4 of 8
Hunter_NX
  • Sorry but you didn't understand. I didn't have the router I want to know if the router will solved my problem
Message 5 of 8
Guru
Something you'll have to try. However again, if you have issues before hand, you need to identify where they are coming from other wise change to a different router may not solve anything.
Message 6 of 8
Hunter_NX
I'll try thanks you
Message 7 of 8
Guru
Be sure to post over in the Nighthawk forum for continued help and information.
Good Luck.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1203 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
