× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Conexion fuera de mi region
David1972
Guide
Buenos dias,
llevo unos dias probando el xr500 y en general va bien pero al intentar conectar con Sud America, India y Australia es imposible conectar habiendo servidores y saliendo marcados en el router.
Si intento conectar en EEUU no hay problema.
La version que tengo instalada es la beta.
Alguien sabe porque puede ser??
Gracias
David
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Liam
NetDuma Partner
Re: Conexion fuera de mi region
Hey David,
Where abouts are you actually located? If these servers you're trying to connect to are Geo-graphically very distant from you, you may find extensive wait times or that you're simply unable to connect. This is more down to most games' matchmaking process rather than something DumaOS can control.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 655 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
