Orbi WiFi 7 RBE973
Reply
IPv6 Manual DNS
IPv6 Manual DNS
I'm using OpenDNS for both IPv4 and IPv6.  When I look at my settings in the Netgear Up app, it shows the DNS resolvers pulling from my ISP for IPv6 rather than the manual ones I entered.  IPv4 resolvers are showing correctly.  So am I to assume that my ISP resolvers are being using instead of the ones I manually entered? I'm including screenshots for reference.
https://imgur.com/a/W8sOc
https://imgur.com/a/Xuh2S
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 4
Accepted Solutions
Re: IPv6 Manual DNS
I just wanted to give an update.  So it seems if Auto-Detect is used when setting up IPv6, no matter what manual DNS servers are entered, the ones auto retrieved from the ISP are used.  Once I switched the setting to DHCP, then the manual DNS servers I entered are used.
Message 3 of 4
All Replies
Netduma-Fraser
NetDuma Partner
Re: IPv6 Manual DNS
I’ve not used up App myself. You’re probably best to contact Netgear directly through their official support: https://www.netgear.com/support/contact.aspx
Message 2 of 4
Re: IPv6 Manual DNS
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Re: IPv6 Manual DNS
Thanks for the update! I will make a note of this and bring it up to the Netgear team to get fixed. Glad that you managed to resolve the issue.
Message 4 of 4
Discussion stats
  • 3 replies
  • 10860 views
  • 7 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
