Orbi WiFi 7 RBE973
Reply
Netgear nighthawk xr500
Mrp3nguins
Follower
I just bought a netgear nighthawk xr500 and every time I use the admin and password information I was given to login it says that it failed to login
Message 1 of 3
Netduma-Liam
NetDuma Partner
Re: Netgear nighthawk xr500
Do you know if you changed these credentials when setting up the XR? If that's the case, you'll need to login with these credentials.
Otherwise, I believe you should be prompted to reset the password after a few unsuccessful attempts using the MAC address of the XR.
Message 2 of 3
Guru
the netgear devices prompt you to change the password when you first log into them. So it shouldn't be your default info.
If you dont know that password, you can try using the password recovery:
https://kb.netgear.com/24220/How-do-I-recover-my-NETGEAR-admin-password-using-the-password-recovery-...
If you didn't setup password recovery, it still asks the questions but there isn't a correct response. So if you don't know the answers or didn't set them up, then you'd need to factory reset to get back in
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 907 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
