× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk X4s AC2600 R7800
shirleeny
Since I updated the firmware to v1.0.2.60 I have had a significant drop in my wifi signal to my devices. I hardwired my laptop to my modem and I was able to receive 117.2mbps. When I reconnected the modem to the router and checked speed, I was only able to get 34.2mbps.
I have checked the speed of my internet using the Nighthawk app, and I am getting 117mbps steady. The unit is about a year old. No obstructions, the only difference between this week and last week is I updated the firmware. What could the problem be? I appreciate any help!
Message 1 of 3
Guru
Re: Nighthawk X4s AC2600 R7800
You'll need to post this in this forum for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
Message 2 of 3
shirleeny
Thank you!
Message 3 of 3
Discussion stats
  • 2 replies
  • 1027 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
