Orbi WiFi 7 RBE973
Reply
Re: DHCP constantly renewing XR500
Mi7ooo
Tutor
Hi all,
I also started getting the same dhcp lease renewal issue. Im using version 134. I have been using it for years but the past few weeks the router started having this issue.
I tried setting up the max dhcp value to 100 and also reserved ips for my devices. It worked for a week and started again.
Please help
Message 1 of 11
Accepted Solutions
Mi7ooo
Tutor
Hi Fraser,
Yes i did that and the router seem to be working fine for now. I flashed version 114 using tftp, did factory rest and then upgraded to 134.
Thanks for the usual support.
MJ
Message 10 of 11
All Replies
Guru
Try setting DHCP range from .100 to .200?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 11
Netduma-Fraser
NetDuma Partner
Did you set the reserved IPs outside the range you set?
Message 3 of 11
Mi7ooo
Tutor
Hi,
I tried the suggested solution, but the issue persists. The router stayed fine for a couple of days though
My modem is huawei hg8245w5.
I dont remember if i have done mf reset on the firmware.
Any tips ?
Message 4 of 11
Netduma-Fraser
NetDuma Partner
Disable DHCP entirely (make sure you've reserved all the IPs) and then it should be better
Message 5 of 11
Mi7ooo
Tutor
Hi Fraser,
Tried disabling dhcp, for some reason it didnt recognize all devices although they have been setup. Re-enabled dhcp again and them couldn’t connect at all to the router.
I did a factory reset and now the router cant boot up . I enter 192.168.1.1 , first time it took me to the license agreement, i accepted it then it got stuck. I used also adv_index but still the same. Did multiple factory resets with no luck. Also turned it off for 10 mins still the same.
I guess the router just died.
Message 6 of 11
Netduma-Fraser
NetDuma Partner
Unplug it from power for 10 minutes, this will let the residual power drain, then plug in, wait 4 minutes and try accessing
Message 7 of 11
Mi7ooo
Tutor
Hi,
I tried, initial page started. Then it asked to accept data collection and i accepted. Then the page where the model of the router appeared. I accepted but then it got stuck and the connection timed out. After that i tried again several times but it always timed out.
Message 8 of 11
Netduma-Fraser
NetDuma Partner
I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://forum.netduma.com/topic/54949-dumaos-is-not-running/?do=findComment&comment=407569
Message 9 of 11
Mi7ooo
Tutor
Hi Fraser,
MJ
Message 10 of 11
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 11 of 11
Discussion stats
  • 10 replies
  • 2261 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
