- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Reset to Factory Default after every firmware update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I read somewhere that it is recommended to factory reset the XR1000 Pro Gaming router after every firmware update? Is this true? I am thinking of factory reset because my 2.4G band sometimes wont allow new devices to connect to it (existing devices connected to it work fine).
If I factory reset the device, but rename my 2.4 and 5G with the same SSID names and passwords, will I need to reconnect all of my home devices or will they still find the WIFI names and connect automatically?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Reset to Factory Default after every firmware update?
You shouldn't need to after every update. We just usually recommend it if you're having issues after an update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! If I factory reset the device, but rename my 2.4 and 5G with the same SSID names and passwords, will I need to reconnect all of my home devices or will they still find the WIFI names and connect automatically?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you use the exact same ssid/password, they all should auto-connect. I switch routers a lot and all my devices switch over automatically when I use the same ssid/password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
