- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WMM & XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
WMM & XR1000
Hello, I´m struggling lately with any kind of traffic from my cellphone (webcam traffic 5 Mbps - 10 Mbps) and this affects to the latency on my PC to the router. I was wondering to start testing with WMM on & off but I cannot find the option on the XR1000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
I don't believe that option is available on the XR series. It would have been under Advanced tab/Advanced/Wireless settings if it was there.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-...
What brand and model# cell phone do you have?
Is PC ethernet connected to the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
Thanks for the rapid answer. I´ll try changing those on my phone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
Nop, keep doing the same. The latency between PC and router become crazy when I put some bandwidth between the phone and the PC. If I use the Internet bandwidth in my phone (like 4K YT) doesn't affect to the PC latency.
Latest fw
ONT Huawei (not a Internet issue)
Channels Im trying the 161 on 1200 Mbps
My phone is a S22u
PC is connected trough the same WIFI6
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
QOS enabled, same thing. The funny part that is the Router not even SEE the local traffic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
The latest one. The info is in the first post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
In fact, I have Auto enable, always on and off..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
Sorry not seeing the version number in your first post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
I put the QoS in always active and 10%. Obviously doesn't work because is internal traffic. The router doesn´t even see it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
Hello community, I got here looking for a weird issue that I never know what it was until I read someone here with the same issue. The thing is when I share my cellphone camera with my PC (both connected to WIFI6 Netgear XR1000) 20 Mbps, the PC starts to having a lot of latency with the router and with Internet too. I realize the last week because a reddit post, that could be the MU-MIMO feature that is enabled in router. I turned off and everything started working as it should. BUT, when past 1 day, it starts to "fail" again, and the feature in the router is turned off. What I have to do, is enable again and reset the router. That´s my workaround so far but I don't know how to fix it definitely.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Lets try a full on factory reset and setup from scratch using a wired PC and web browser:
Afterwards, set MU-MIMO to enabled.
Set manual channels to 1 and 40.
Be sure that Smart Connect is enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
Literally I put that info in the last message.. I do not use Smart Connect. This happen in both 2.4 & 5ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
I don't mean the connection method I mean via a third party app, phone manufacturer app etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WMM & XR1000
So how about some feedback on the question presented. Need more details to better help you out.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
