- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
X5000 - Can't connect over VDSL2 PPPoE (UK)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have the new Netgear XR500 DumaOS powered router having upgrded from a Netduma R1. The unit has had problems since day one and intially refused to establish a internet connection to my ISP with the setup wizard failing everytime. Instead I connected my XR500 to my Netgear DM200 modem in routrer mode. Not wishing to be defeated I tried again to get the XR500 connected directly. This time I set the VLAN tag my ISP requires (101) in Adavanced option, then I went back to Internet settings and tried again. Success, the XR500 connected.
For a few days all was well but the the host filtering stopped working for one of my connected devices. Fraser at Netduma assisted but could not resolve so I restarted the XR500. Since then the XR500 refuses to connect to my ISP. I have tried hard resseting the device and going through all the steps I followed previously to no avail.
If I swap my DM200 back into modem/router mode it works fine with all the same settings.
If I swap an old Zyxcel router with Vigor modem everything works fine also.
Can anyone help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X5000 - Can't connect over VDSL2 PPPoE (UK)
I would post this here:
Since you have the gaming router.
Also give the DMZ on your modem a try for the XR500 router if your going to run the modem in router mode.
Good Luck.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router MK83+ (Router Mode) | and RBK853 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR700, XR1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the links. I was able to get the router working again by downgrading the firmware to v2.1.0.6. Even the very latest firmware, v2.2.1.10 breaks my PPPoE connection, reverting back to the old firmware restores normal service.
I may try v2.2.1.10 again tonight and play around with the VLAN tag. That is how I did have this working previoulsy on a later firmware version when it suddenly stopped working following a router restart.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should have mentioned that I've ditched the DM200 in favour of Dreytek Vigor 130. The XR500 and they Dreytek are working fine with the old firmware on the XR500. I've not specifically needed to set a VLAN ID tag, it seems to auto negogiate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
9 | |
8 | |
7 | |
5 | |
2 |
