× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
XR1000 DumaOS not loaded yet!
DK350Z
Star
Hi,
Firstly sorry if this has been answered before, however I have searched this forum and have not found a 'stable' solution.
I purchased a XR1000 a while ago and appeared to set it up without problems. I changed the SSID and password to match my old R7000 router to make setup easier (and I don't have access to my soler inverter and battery to connect them to a new SSID). Throughout the setup I was able to see the DumaOS with my browser, and it loaded after I had completed the setup.
Later I tried to login and it came up with the message DumaOS not loaded yet! (image attached). I tired using default gateway IP (192.168.1.1) and routerlogin.net, neither worked. I tried using Chrome and Edge, and still the same message. I restarted the router, no change. Finally, as a last resort I tired resetting the Routing (holding for 30 seconds). Again I went through the entire setup, changed SSID/password, and DumaOS was accessible again hooray! However, the next day I get the same message "DumaOS not loaded yet!" I have not been able to access the DumaOS for at least a month now.
As a temporary workaround, I can access limited functionality through my Nighthawk app, and I can access the router through a browser using http://routerlogin.net/adv_index.htm, however this also appears to have limited functionality.
My firmware version is 1.0.0.52. I believe I started at an earlier version, but the problems started before I updated, I think.
Message 1 of 34
Netduma-Liam
NetDuma Partner
Re: XR1000 DumaOS not loaded yet!
Sorry to hear this, could you please try going to System Information -> Installed Rapps -> Click the three-line menu and change the number of retries to 5?
You may need to reboot the router after this, then let us know how you get on!
Message 2 of 34
DK350Z
Star
I'm afraid there is no System Information menu when I access using http://routerlogin.net/adv_index.htm, or should I be looking somewhere else? The attached image shows what I can access.
Message 3 of 34
Netduma-Liam
NetDuma Partner
Hmm, OK, what's the exact make and model of your modem?
Message 4 of 34
DK350Z
Star
It's a Netgear router, not a modem. It's the Nighthawk Pro Gaming Router. Model XR1000.
The address http://www.routerlogin.net and 192.168.1.1 can no longer access the DumaOS with the error "DumaOS not loaded yet!"
 The only way to access is with http://routerlogin.net/adv_index.htm which appears to use a simple interface. I can't remember where I found this link, either somewhere in these forums or through other searches
Message 5 of 34
Netduma-Liam
NetDuma Partner
My apologies, I'm referring to the upstream modem/router that the XR1000 is connected to. If there isn't one, what does the XR1000 connect to for internet access? An ONT perhaps?
Message 6 of 34
DK350Z
Star
I'm sorry, my bad. I didn't think the modem would be related. It's a router/modem that was provided by my ISP. It looks pretty generic with no model number. Many years ago I worked out how to set it to bridge mode with my old R7000 Router. The closest thing I can find to a model number is TGiiNet-1
Message 7 of 34
Netduma-Fraser
NetDuma Partner
Is this the modem you're using? https://www.manualslib.com/manual/1198716/Iinet-Tg-1.html when you set up bridge mode previously, was it done by selecting a LAN port of MAC/IP address? If the later you'll need to update it for the XR.
How is the XR connected to power - is it via a power extender or direct to the wall? If an extender can you try direct to the wall, factory reset so you have access again, do Liams suggestion with retries, reboot from the interface after making that change, wait 2 minutes before accessing then see how long it goes before being unaccessible please.
Message 8 of 34
DK350Z
Star
That does look like the modem I have. It's been a long time since I first set it up, so I'll need to try and log directly into the modem with a laptop to see how it's configured. It may need to be, and worth factory resetting the modem as well and starting from scratch again.
It's getting late here now, so I won't be able to try again for at least 15 hours. I'll let you know how I get on. Cheers
Message 9 of 34
DK350Z
Star
Hi @Netduma-Fraser and @Netduma-Liam,
Ok so I've factory reset both my Modem and XR1000. I then put the Modem back into Bridge mode, the XR is connected via LAN port. I then logged into XR successfully, completed setup and arrived to the DumaOS, Yeh! 🙂 I have gone to System Information -> Installed Rapps, and set retry attempts to 5. Restarted, waited about 3 minutes, logged back in and DumaOS is still working.
I'll monitor tonight and over the next couple of days to confirm it still works.
Thank you so much to you both for the support, very much appreciated!
Message 10 of 34
Netduma-Liam
NetDuma Partner
OK awesome, thanks for letting us know!
Message 11 of 34
DK350Z
Star
It's been a couple of days now, and unfortunnately I'm back to the beginning with "DumaOS not loaded yet!" showing up when I try to enter the webpage 😞
I have tried Chrome and Edge, and I've cleared the browsers cache and I have rebooted the router, still no change. I'm not sure what else to try
Message 12 of 34
Netduma-Fraser
NetDuma Partner
Upgrade to the same firmware, this will bypass the boot process and any issues there https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP once complete perform a factory reset and see if it works better after that.
Message 13 of 34
DK350Z
Star
Hi Fraser,
I've tried the procedure in the link you've provided and can't seem to get it to work (I've tried a few times over tha last couple of days). I'm always getting "connect request failed" after about 20 seconds or so. I'm assuming I'm not doing steps 7 to 12 correctly and the router is not going into the correct state to accept firmware. I'm not sure what I'm doing wrong as I think I'm following the steps correctly.
I've varied the time I hold the reset button after 10 flashes from instantly to a few second but it does not make a difference. I've also tried to ping 198.168.1.1 and always see the repose ttl=64, not ttl=100 as some other people suggest in other forums.
What ever I did with steps 7 to 12, it did factory reset the router. I have changed Rapps retrys back to 5 again.
Message 14 of 34
Netduma-Fraser
NetDuma Partner
Just to double check, did you enable TFTP for Windows as per the link at the bottom of the guide?
Message 15 of 34
DK350Z
Star
Yeah I did that. I worked that out after I had an error along the lines of 'command not recognised'. then I followed steps to install TFTP and restarted the computer. Then I encountered the error connect request failed
Message 16 of 34
Netduma-Fraser
NetDuma Partner
Okay no worries, try using this method instead which uses software rather than the command prompt https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Message 17 of 34
DK350Z
Star
I'm afraid I can't get that to work either. The problem definitely appears to be I can't get the router into the correct state to recieve the firmware.
Using the TFTP client method linked below, my routers led never flashes orange during bootup. It's a solid orange, then green when it's completely started (I think the tutorial is aimed at a router that is curunpt or bricked). I tried clicking on 'push' anyway but nothing happens, and the router continues to boot normally. I also tried the 'holding reset while turing on' method described in the command prompt procedure, but again the client cannot deliver the firmware, the router just factory resets and I have to set it up again.
Sorry, I really wish I had better news! The plus side is that I can confirm that everytime I do something that factory resets the router, I get DumaOS back, but after a couple of days it's back to "DumaOS not loaded yet!" Reboots don't seem to matter, I can reboot as many times as I like just after resetting, and Duma still works. Something happens over the corse of 1 to 2 days to stop it working each time...
Message 18 of 34
Netduma-Liam
NetDuma Partner
We have seen a couple of reports that downgrading to previous firmware, factory resetting, upgrading back to current firmware then resetting again resolves issues like.
I realise that's quite an ordeal and may be quite time consuming, but perhaps it's worth you trying?
You'd need to do this through the interface as the TFTP method doesn't appear to be doing much for you, let me know if you need any assistance locating previous firmware versions etc!
Message 19 of 34
DK350Z
Star
Thanks Liam, I'll give it a try. Internet and local NAS access has been been in high demand from my wife and family, so I'll have to find a gap where I can work on it for a while ;-). I'll feedback once I've given it a try.
Message 20 of 34
DK350Z
Star
Hi @Netduma-Liam and @Netduma-Fraser ,
Sorry it's been so long, the family started working and schooling from home, so I installed my old router for reliability. I have finally managed to install the XR1000 again and try your suggestions.
I loaded old firmware, factory reset, updated firmware and factory reset again. I now have a new symptom when logging in. I get an error "Missing JSON response." if I click ok there is no response. I have tried Edge and Chrome and cleared cache on both browsers. Edge shows the error mentioned and Chrome just shows a spinning loading icon (images attached).
However, out of interest I tried Avast Secure Browser and it works! Last time it took a few days for DumaOS to stop working, so I'll report back in a couple of days. Do either of you know why the other browsers will not work even after resetting the router and clearing the cache of both browsers?
I think the next step will be requesting RMA before the waranty runs out.
Message 21 of 34
Netduma-Liam
NetDuma Partner
No problem at all!
OK we're making progress, glad to hear you can use it in one browser at least. I have seen reports of this problem before, it does sound like a cache issue so it's odd that clearing cache didn't fix it for you. If you hit F12 then tick 'disable cache' at the top, then refresh the web page, do you still get the same error?
Otherwise, let us know if you run into any other problems.
Message 22 of 34
DK350Z
Star
Hi Liam,
I hit F12, and found "Disable cache (while DevTools is open)" under setting/Preferences. I don't get the "Missing JSON response" error, however nothing loads (apart from the red background). I've refreshed multiple times and waited up to 15 minutes. Seems to be the same for both Edge and Chrome. As soon as I exit DevTools and refresh I get the error message again.
I tried to reset Chrome under settings/Advanced/Reset and clean up, but no change. I might try re-install Chrome just for the heck of it, see what happens.
But, Avast Secure Browser is still working today! 🙂 Fingers crossed it remains this way.
Message 23 of 34
Netduma-Liam
NetDuma Partner
That's very strange, OK please do let us know how you get on!
Message 24 of 34
DK350Z
Star
Thanks Liam,
Looks like this might be a completely new problem. Should I close this thread with the accepted solution being your post from 2021-06-22 10:37 PM and start a new thread?
I get the error "Missing JSON response" on all browsers on my PC now. Out of interest I used Chrome on my wifes laptop yesterday and it loaded DumaOS fine yesterday, but today I get the same error on her laptop as well. Seems that once a computer has logged in a couple times from a browser, something changes and causes it to error from that point onwards.
Message 25 of 34
Top Contributors
Discussion stats
  • 33 replies
  • 8999 views
  • 9 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
