- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Disconnects on lease expiration from xfinity gateway in bridge mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Question: The XR500 disconnects all devices when the WAN lease is renewed or static IP's are assigned. Is this just the way the product is designed? Do I need to buy a different router to fix this issue? What is the recommendation from the community here?
Background: I recently switched from AT&T to xfinity for internet service. Since I use the amazing XR500 to manage bandwidth for all the gamers and video streamers in the house, I had the gateway configured to bridge mode to avoid double NATing and other overhead that might degrade service. After this configuration was implemented, I noticed intermittent disconnects in games, streaming and MS Teams calls.
After some monitoring and investigations, I discoved that every disconnect event aligned exactly with a lease renewal event on the XR500. The xfinity lease is set to two hours so I get disconnects every hour. Also anytime I assign a static IP address in the LAN configuration, all devices are disconnected. This leads me to believe that when the routing table in the router is updated, it disconnects all devices.
I have contacted xfinity and they said they might be able to increase the lease time, but ultimately referred me to have a static IP address with the Comcast Business organization. I can only assume this will cost big bucks and honestly should not be necessary.
Request: Based on other posts in this forum it appears this is a typical problem, but the only solution I've seen is to go with a different router. I'd rather not do that as I'm very happy with the router aside from this new issue. If I do buy a different router, I'd want to make sure that I don't have this problem again, so I'd want to make sure the new router won't have this issue. Looking for recommendations.
Gateway: xFi Advanced Gateway TG3482G (in bridged mode)
Router: Nighthawk Pro Gaming XR500
Router firmware:
V2.3.2.56 |
DumaOS: A7Legit
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
.40 alone did not resolve my issue, but this hotfixed image from DumaOS sure did.
V2.3.2.40-C424a |
Source: https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Disconnects on lease expiration from xfinity gateway in bridge mode
See my post about the topic: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Ethernet-randomly-disconnects-for-a-fe...
Roll back to the .40 firmware and see if that does anything for you. So far, I'm going on about 20 hours now with no drop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have reverted to .40. I'll report back on the result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
V2.3.2.40-C424a |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
