× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR700 Problems with MedieServer (Firmware V1.0.1.10)
Jingaker
Guide
Hi,
Just got my new Router and it´s works great except the medieserver thats can´t show
the media at my LG-tv in a proper way.
When you use browse folder you got both folders and mediefiles at the same time
in the root catalog. With my old router I just got the folders that I share from the
router and the usb drive.
Are there someone how have the same problem or is this standard on Netgear routers.
Could It has to do with the new firmware?
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 12
Guru
Re: XR700 Problems with MedieServer (Firmware V1.0.1.10)
Are there any ReadyShare features with in the XR menus? Check to see if any are available and enabled...
Message 2 of 12
Netduma-Fraser
NetDuma Partner
Have you configured ReadyShare correctly on the router? Did you use this prior to the update?
Message 3 of 12
Jingaker
Guide
I hope so, attach a picture of the configuration. I have not used ReadyShare before because I had an Asus router before.
Message 4 of 12
Netduma-Fraser
NetDuma Partner
Can't see the picture as it hasn't been moderated yet. Can you upload to a service and link to the image?
Message 5 of 12
Jingaker
Guide
Message 6 of 12
Netduma-Fraser
NetDuma Partner
I think you'll need to tick the first box on the right hand side to local readyshare
Message 7 of 12
Jingaker
Guide
I have done that but still I have the issue left. What´s happen are that
when I open media on my tv and choose video and foto and click on
browse folder I got a mix of folders and files at the root level.
I expect only to get my folders that I have shared from ReadySHARE
in the root directory or is that only for Asus router and will not work
with Netgear routers?
Message 8 of 12
Netduma-Fraser
NetDuma Partner
It is a Netgear feature so I'm not too familiar with it. I would suggest contacting them directly by logging in here: http://support.netgear.com/ and creating a ticket or calling their support line.
Message 9 of 12
Jingaker
Guide
I will do that. Thank´s a lot for your help
/Johan
Message 10 of 12
Altsai
NETGEAR Expert
did you also enable SMB 1.0?
are you able to find the files via SAMBA protocol? e.g., \\jingmedia?
Message 11 of 12
Altsai
NETGEAR Expert
Message 12 of 12
Discussion stats
  • 11 replies
  • 2921 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
