- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
I was thinking of connecting a LAN cat6a cable between the router and the modem. Can you help me get a better connection? ( now I'm connected with a cat5e)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
so every time i have to restart the modem first then the router? the line is not consistent ping is unstable quite sure that I don't have to restart the router first and after the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
The router relies on the modem for a good connection, so it's always better to reset the modem first (so it refreshes your Internet connection). But it's not essential.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
I connected to the xr500 a fritz box 7590 that doesn't have the possibility to put the dmz on the ip wan of the router you advise me to put the nat type open on the xr500 or I leave protected or you advise me to do other to optimize the connection for to play and set the two devices correctly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
Does the Frtizbox have a modem mode or bridge mode you can configure it to?
Are you getting closed NAT? If it's open, there's no real need to change anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
but is there the possibility of inserting the xr500 as an exposed host I insert it in this mode? or is not the same as the DMZ
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
I would just use the DMZ if possible otherwise that should be fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
eThere is no DMZ on the fritz box only the exposed host another thing would you advise me to put the ip of the xr500 static or leave it automatic?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
perfect, the static ip I leave it only on the modem or I put it static also on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
I put the xr500 router ip wan in the real-time priorities of the fritz box modem. Did I do well or could it cause problems?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
I believe it is a type of QoS if in real time I put the xr500 it should not prioritize the traffic directed to the router and therefore it should not be better? I do not know
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
so is it enough for me to activate the exposed host to make the router use only its data traffic?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
sure that you need the static ip address from the modem to the router? the exposed host does not work via mac address? one last thing then everything is there is an option (in the fritz box) that says "Allow automatic door enabling for this device" I select it or not?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
in theory it should allow the xr500 to open its doors autonomously from what it says but the exposed host shouldn't do it already?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 priorità
- « Previous
- Next »
