× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ethernet plugged in question
Mark9816
Apprentice
I have my ethernet for my pc plugged in to port 1 but on the front the light is light under port 4 and it dose this for all ports nothing maches up? Plus my pc gets a oreange light and my ps4 gets a white light why??
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: ethernet plugged in question
The port experience you've described was present on the very early production products, it is purely aesthetic and will not affect the performance of the router. The orange light means that either the connection is limited to 100mbps - most likely due to the ethernet cable used or that it's not using data over that limit at the time.
Message 2 of 3
Mark9816
Apprentice
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 960 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
