× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NightHawk S8000 GS808E power adapter replacement
daeshik
Follower
Purchased around December 2019, the power adapter got water damage.
I cannot locate any replacement part store to buy this.
How do I get the replacement power adapter for this?
Should I just shop around to get 3rd party product for 12V 1A adapter for this?
Thanks,
Daeshik.,
Model: GS808E|Nighthawk S8000 Gaming & Streaming Advanced 8-Port Gigabit Ethernet Plus Switch
Message 1 of 2
schumaku
Guru
Re: NightHawk S8000 GS808E power adapter replacement
Sure. Check voltage, power, and +/- on the DC plug.You find Netgear replacement power supplies on eB or AMZN, connectors ar the same for these and the common routers when I have it right.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1381 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
