× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX200 - Can this model be bridged AND act as an AP?
LeeLawson
Follower
I'm wanting to use the nighthawk RAX200 as a bridge, but also need to retain the AP. Is this possible?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Accepted Solutions
Guru
Re: RAX200 - Can this model be bridged AND act as an AP?
No.Bridge mode is just a connection from router<----->router with only the ethernet ports active.
The mode you're looking for would be extender mode and the RAX200 doesn't have that mode.
Message 3 of 3
All Replies
Guru
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Check the user manual for these options. Most RAX routers have AP mode at least. The last RAX80 I had also supported wireless bridge mode.
Thank you.
Message 2 of 3
Guru
Message 3 of 3
Discussion stats
  • 2 replies
  • 1669 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
