Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R6700v3 - Whatsapp calls won’t connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-16
09:05 AM
2020-09-16
09:05 AM
Hey everyone, I’ve seen over 100 posts about this but not a single solution.
I just got this router. Everything works well except Whatsapp.
I’m using iPhone 11 and every time I make voice or video calls on Whatsapp or receive calls and touch “answer” button, the internet connection stops working. I always have to switch to cellular data to be able to talk or video chat.
Is there any solution to fix this?
This doesn’t happen on any other apps. Only whatsapp.
Thanks,
Dave
Thanks,
Dave
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-10-02
08:13 AM
2020-10-02
08:13 AM
Re: Nighthawk R6700v3 - Whatsapp calls won’t connect
I have the exact same issue. Ever since the IOS 14 update I can’t WhatsApp call through my Nighthawk R7000. It will keep reconnecting. If I call through FaceTime it works fine. If I call through WhatsApp using my XFi router in basement it works fine. Just no WhatsApp calls through R7000.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-15
05:09 PM
2021-02-15
05:09 PM
Hi all,
I am having problems receiving WhatsApp calls. The calls keep reconnecting and sometimes it just says poor signal and doesn’t work. The problem is with the R7000. I am surprised because I use Verizon Fios (fiber) and my speed tests reach 300 MBPS. The outgoing WhatsApp call are fine just the incoming calls have issues. When I switch from WiFi to Cellular it works well. I think Netgear should resolve this problem as I am not the only one complaining. Thank you.
Ola
Ola
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-15
07:28 PM
2021-02-15
07:28 PM
I found out the problem is with IPhone. You need to go to your settings-WhatsApp-then enable local network for WhatsApp.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-15
07:29 PM
2021-02-15
07:29 PM
I found out the problem is with IPhone. You need to go to your settings-WhatsApp-then enable local network for WhatsApp. This should work
Model: R7000|AC1900 Smart WIFI Router
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-18
05:57 AM
2022-07-18
05:57 AM
Hey
Any idea where to solve the same issue on Android WhatsApp? I didn't find the place to allow the network to run
Thanks
Thanks
Message 6 of 6
