Sobendo's avatar
Sobendo
R7450 Loosing connection to internet on WIFI 2.6 or 5G
Has anyone had issues with loosing internet connection on wireless use? I connected hardwire RJ45 and works fine and never looses connection.
  • FURRYe38's avatar
    What model NH router do you have? R####?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channel configurations are currently set on the router?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON
  • michaelkenward's avatar
    michaelkenward
    On which wifi clients? All of them? Only some?
    What do the wifi LEDs look like when this happens?
    • Sobendo's avatar
      Sobendo
      Thank you but. Factory reset seems to have worked
        michaelkenward
        That's good. An earlier message from you suggested that a factory reset did not fix the problem.
