mahisamk's avatar
mahisamk
Initiate
Oct 03, 2014
R7500 Keep Dropping Connection
My R7500 keep dropping connection to internet on both wireless and wired device. The signal is always strong and showing connected but just can't get access to internet either apps or website. Need wait about 1 to 2 minutes until the router reconnect itself. This issue happened about every hour. The home network still working, and I can access files from other computer or device through R7500. Just can't get internet access.
The firmware is the newest one.
  • Anonymous's avatar
    Anonymous
    Dec 25, 2014
    Hello,
    I have no problems in the 2.4 and 5 GHz band, the router is already two weeks without anny trubbels, I have the latest firmware installed steps:
    1. router to default settings
    2. FW installed (76)
    3. routern to default settings after upgrade
    4. router reset
    No problems with connection issue; stable:D
