×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk C7000v2 Mesh / Extending
Allen_Jones
I have a Nighthawk C7000v2. I would like to extend the range but not sure how. It's just "OK" in parts of my house, but get out to my garage (100+ feet away) and sketchy. I am going to parking an RV by my garage and want to extend good WiFi out there.
Message 1 of 7
Accepted Solutions
Guru
Re: Nighthawk C7000v2 Mesh / Extending
Yes. Can hook up just about any thing. EX or EAX series extenders have wired AP modes that have the LAN port in back. A R or RAX series router can work in AP mode as well.
Wireless Access Point= Any device that broadcasts a wifi signal.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 7
All Replies
Guru
That kind of distance, you might be best to put in a CAT6A STP lan cable out the garage and then put in a wireless AP unit that's connected to the lan cable for best use and operation.
Message 2 of 7
Allen_Jones
So are you saying run a cable from my current nighthawk modem out to my garage and then hook another unit up to that out there? Whats a wireless AP? Thank you
Message 3 of 7
Guru
Message 4 of 7
Allen_Jones
Thank you!
Message 5 of 7
Guru
Message 6 of 7
Guru
Just fyi, not all of the gears EX extenders have access point mode. The higher priced ones do so its worth checking into the ones you look at to see if they have that feature.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 7 of 7
Discussion stats
  • 6 replies
  • 1255 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
