- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk MS60 - Vulnerability reported, check software updated (already updated)
- Mark as New
- Bookmark
- Subscribe
- Permalink
When using the Nighthawk app it lists vulnerabilities on all my MS60 satellites.
QUOTE:
Device highly recommended update
The device is vulnerable to accepting unsecure protocols and services from caber threats. We recommend that you check for the latest manufacturer software update.
Using current firmware MS60-V1.1.7.134_2.0.65 and the support page only has a download for that same firmware version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk MS60 - Vulnerability reported, check software updated (already updated)
Not sure what your message is about. Are you seeking help or offering advice?
Try here for the MS range of routers:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was just looking for a way to resolve the issue that it says there's an update and there isn't one available (publicly at least). Unless there's some other firmware location that is tucked away on their websites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What tells you that there is an update available?
