× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
SSH Issue on MR60
MR60User
SSH Issue on MR60
I installed the Nighthawk MR60 MEsh with two satelites today and since then I am unable to SSH into otherdevices on the network. Is SSH blacked by default? Can it be enabled?
Thanks.
Message 1 of 4
Guru
Re: SSH Issue on MR60
Does this happen if you turn OFF the MS and let all devices connect with the MR?
Message 2 of 4
MR60User
Firmware is V1.0.6.116
Modem is a CM1100 that I own (not ISP)
I was able to succesfully ssh to other devices on my network (which is all I am concerned with...nothing outside of my network) just before the install. I have not been able to ssh since MR60 was installed as the router/wifi. I can ping the other device(s), but the ssh attempt times out which leads me to believe the MR60 is inhibiting that connection.
Message 3 of 4
Guru
Possible. There is more newer FW that you can try, however may not fix. This maybe something that is not supported on the MK series and NG may consider SSH from the outside a security concern and not support it.
https://community.netgear.com/t5/Nighthawk-Mesh-System/New-MK6x-series-MR60-MS60-FW-v1-1-6-122-Relea...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1390 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
