Orbi WiFi 7 RBE973
Reply
Connecting Xbox wirelessly to c7800
80roc80
So I normally have my Xbox hooked up wired I moved it to another room and tried connecting via Wi-Fi have had it hooked up to Wi-Fi in the past and I had no problem now there’s no said to even see to Connect to when I try it says my security protocol won’t work, and that I am not hooked up to WPA/wpa2 which when I check my settings I am connected to WPA\WPA2
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 7
Accepted Solutions
Guru
Re: Connecting Xbox wirelessly to c7800
factory reset on the xbox?
If its just one device having the issue, I'd be looking at that device closer
Message 4 of 7
All Replies
Guru
Are any other devices having issues?
Or just the xbox?
are you using any special characters/spaces in the ssid/password?
did you "forget" the network on the xbox and reconnect to it?
anything else change in the C7800 since you had it wirelessly connected?
Message 2 of 7
80roc80
All other devices are working and connecting fine, using same passwords /ssid. I have tried everything I can think of besides factory reboot
Message 3 of 7
Guru
Message 4 of 7
80roc80
Yea that worked I was hoping to not have to but was my las option. Thanks everyone for your help
Message 5 of 7
Guru
If you mark it solved, it might help the next person
Message 6 of 7
Did you notice any latency issues when changing to WiFi? My current router courses lag problems on most games when I change to wifi even though I am close to the router. New router on it's way soon so hopefully might be able to dich the cable
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1810 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
