Steve_tanner's avatar
Steve_tanner
Nighthawk AC1900 R7000 2.4ghz wifi not working
I'm running the most recent firmware V1.0.7.6_1.1.99. So my R7000 will broadcast 2.4ghz inconsistently, until none of my devices are able to connect to it. The devices will be "No internet, secured". I've run troubleshooting on two different laptops on that network, and both devices give me different reasons as to why they cannot connect.
I've done a number of factory resets, changing the SSID's each time. I've maybe been using this router for 24 hours. It's worth noting that my 5G network works well enough.
  • Hi kman68,
    Reset the router to factory default and try to reconfigure it manually.
  • Have you tried changing the Wi-Fi channel?  Perhaps the one in use is unusable due to too many neighboring networks or interference.
    • Steve_tanner's avatar
      Steve_tanner
      I have tried that, actually. No change. Very few wifi connections around me anyways. Definitely not enough to interrupt my signal.
    I think that means something different. That means I believe that they devices ARE connected to the router but there is NO Internet connection? That is they ARE connected to the LAN but not the WAN.
    What were the various reason you did get?
    On the failing PC's/Laptops please open a CMD prompt and run IPCONFIG /ALL on them and paste the results here, especially if one is connected and one isn't.
    Important items would be the IPv4 Address, Default Gateway, DHCP Server, and DNS Server if you only want to post those without all the other
    info.
    On the failing wireless devices can you connect a cable to rule out something on the LAPTOP causing a problem?
    Also, enable logging if you had not and see if anything appears there?
    Did it work with older F/W versions? Have you tried going back to the last one you had?
    Did you re-enter all your settings after flashing the new version?
      Steve_tanner
      OK! A lot of info to pack into this, so I'll piece by piece here:
      The most common problem Windows troubleshooting finds is "The DNS server isn't responding" I also occasioanlly get "Your computer appeats to be correctly configured, but the device or resource (www.microsoft.com) is not responding.
      The info from my IPCONFIG /ALL is as follows:
      IPv4 Address: 192.168.1.5
      Default Gateway: 192.168.1.1
      DHCP Server: 192.168.1.1
      DNS Server:: 192.168.1.1
      I can confirm that a wired connection works with both laptops unable to connect to the 2.4ghz network.
      and I have to admit I'm not suuuuper savy when it comes to networking issues so I'm not sure what these last two lines mean:
      "Did it work with older F/W versions? Have you tried going back to the last one you had?
      Did you re-enter all your settings after flashing the new version?"
      • IrvSp's avatar
        IrvSp
        Master
        Those are questions about what you had before and did after if you updated the firmware.
        I assume you updated the firmware to get to the latest release, the router was NOT shipped with that version.
        If so, what version were you using before you updated? Don't know, that is OK too.
        Last question is vital. If you DID update to the latest firmware, you should (must according to NG) re-enter all your settings. Manually, not re-loading saved settings.
        I noticed in your initial post that you've tried 'Factory resets'. That means you did the pressing and holding of the recessed button in the back, right? Not powering off and on the router right?
        Also you said " I've maybe been using this router for 24 hours." but does that mean with the latest firmware or that the router was brand new with that level of flash and you've only had it a day? If it is new, CALL NG support as you might have a bad router (or return it to the place of purchase and get another).
  • Steve,is right, my 2.4ghz never woks.  Past time to return.
    i have discovered that the model R7000 has the same problems. These were rated very high and many many users have the same problem. Netgear refuses to upgrade their FW.  Class action suit is clearly in order, or if anyone wants to buy this worthless device let me know.
    has anyone found a solution to this?
    i have put in countless hours and may need to find another modem/wifi device
    i
  • I almost have the same problem. Since I upgraded to the latest version, the signal quality of the 2.4Ghz network is extremely poor. Even the signal quality of the 5Ghz network is better.
  • WOW...I can't believe the trouble this router has caused.  I have been watching all the threads about the 2.4 GHz not working for the last year now.  After trying v1.05... and v1.06...I previously resorted to running on software v1.0.4.28_1.1.64.  It worked well enough for a while.  I made some changes to allow me to use PLEX...since then, I started having some minor issues.  So I decided to look up the software versions again to see if it got any better.  It seemed like people were okay with the latest version, so I thought I would give it a shot...
    About a week ago, I decided to try upgrading the firmware to V1.0.7.6_1.1.99 to see if they finally got it working.  I have tried numerous times...and in numerous ways.  Yes, I have tried a factory reset and entered in fresh programming (not an import of backup settings).  I tested it as I went to see if there were any particular settings that would trigger the problem.  Unfortunately, it didn't show until about 24 hours later.  I went back down to v1.0.4.28_1.1.64 and now it also seems to be having issues with the 2.4 GHz.  I upgraded today to 1.0.7.10_1.2.3...including a factory reset and freshly programmed inputs.  No go.
    I'm going to try one more time going to the V1.04.  If it still has issues with 2.4 GHz, I'm done.  This is rediculous that they never fixed the problem.  I have read so many threads on this site about the problem and some things work for some people and some do not.  That's a problem.
    • kman68's avatar
      kman68
      Star
      Same issue with the R7000.  It is driving me nuts.  I guess they still haven't fixed it?  Over the last couple of months my 2.4ghz band has dropped to 4Mbps down and .5Mbps up on average.  I have 300Mbps cox internet and my 5ghz band easily runs at 200Mpbs.  2.4 was running at 80 to 100Mbps.  Very frustrated right now.
