Orbi WiFi 7 RBE973
Reply
Wireless router R9000 setup without modem
goreduke
How can I set the router without Internet connection?  I don't want an internet connection and do not have one.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 6
Accepted Solutions
antinode
Guru
Re: Wireless router R9000 setup without modem
> [...] I tried to do it using your iPhone app but it wouldn't go beyond
> the screen where it checks for the Internet connection.
   It's Netgear's "iPhone app", not mine (and Netgear may have more than
one, as the User Manual says), but I'd try the web-browser interface.
Look for "Use a Web Browser to Access the Router" in the User Manual.
      [...] When you access the router, the software automatically
      checks to see if your router can connect to your Internet service.
I assume that there's a way to skip that step (or wait for it to fail).
(If not, then you might need to take the thing somewhere where you can
connect it to something long enough to get it past that step.)
Message 4 of 6
All Replies
antinode
Guru
   What does "set the router" mean to you?  Set up (configure) the
router?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Ignore the parts about
connecting to the Internet.
   Is there some actual problem which you are trying to solve?
Message 2 of 6
goreduke
Yes, I meant "configure" ... I tried to do it using your iPhone app but it wouldn't go beyond the screen where it checks for the Internet connection.
Message 3 of 6
antinode
Guru
Message 4 of 6
goreduke
Thank you for your patience! II'm a complete novice on this board and somehow assumed you were with Netgear and "yours" really meant "Netgear's" app.
I will try the web browser again ... I did access the router that way but was also stuck on the need for an Internet connection, but do not remember if there was anything that could serve as a workaround.
Message 5 of 6
goreduke
Yes, it worked via the web browser, thanks
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3523 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
