× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
5025895M005FE
thelung
5025895M005FE
Corrupt Firmware after internet drop out blinking red power light
Unable to use or restore firmware
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 7
Guru
Re: 5025895M005FE
sounds like you might have corrupted the firmware during the update.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 7
thelung
Re: 5025895M005FE
hi
thanks for the reply im unable to reflash the firmware as im not good with computers
is there any o way this can be done with granting romote access
thanks
Message 3 of 7
Guru
Re: 5025895M005FE
You don't have to be good with computers. The guides walk you through each step of the process.
There's even a video example of how to do it.
Message 4 of 7
thelung
Re: 5025895M005FE
Just tried again and the firmware flash gets about three quarters of the way on first flash then fails
Message 5 of 7
Guru
Re: 5025895M005FE
what error does it give you?
What type of device are you using?
did you flash with tftp or nmrpflash?
If tftp, did you enable it within windows?
Message 6 of 7
thelung
Re: 5025895M005FE
No error code just stops after flashing
Just over half way on the progress bar
I’m using a window 10 laptop and have enabled tftp trying to re flash a netgear X6S extender
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1117 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
