× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
5G WiFI band has sluggish performance onRAX43v2
cr5720
Follower
Connecting to 5ghz wifi band performs sluggish. Delays every 10-15 minutes, 3-7 second delays on web pages.
Switching back to the 2.4GHZ band performance is as you would expect.
After a router reboot, performance is acceptable for about 3-4 days, then the poor performance returns. Any guidance is much appreciated.
Message 1 of 2
Guru
Re: 5G WiFI band has sluggish performance onRAX43v2
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Smart Connect, Beamforming, MIMO, Armor, Smart Parental Controls or Circle, Traffic Meter enabled?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 409 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
