×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
AX12 RAX120
turtledivers
Follower
AX12 RAX120
I am able to successfully connect my Apple iphones (Apple phones versions 11-13 with updated software) to my Nighthawk AX12 RAX120. However, once i do so, it seems the cell signal and the wifi signal seem to be competing and so the internet is slow and sometimes pages don't even load. When I turn the wifi off on the phone, it works like a charm. But if I turn the wifi back on, it slows or stops connections. thoughts on how to allow Wifi to supercede cell signals on iphones when the wifi is on?
Message 1 of 2
Guru
Re: AX12 RAX120
What version of the router do you have? v1 or v2?
How do you have the wifi and advanced wifi settings configured on the router?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347.  Under Advanced Tab/Advanced Settings/Wireless Settings
Also disable WiFi Private IP address on your phone as well:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/m-p...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Discussion stats
  • 1 reply
  • 396 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
