× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AX1800
Netassist
AX1800
Hello,
I am unable to connect my AX1800 EAX1500 wifi mesh extender. I am not able to find the network for NETGEAR_EXT. I am trying to extend my night hawk RAX80 router.
Message 1 of 3
Guru
Re: AX1800
did you set it up using the wps method of setup?
If so, this installs it in mesh mode. meaning it uses the same ssid as the router and lets devices roam between router---extender based on their own roaming protocol.
Message 2 of 3
Netassist
Re: AX1800
Thanks. I will try that. The RAX80 finally found the extender and the app was able to install it once the netgear_ext network was connected. It took 4 resets on the extender to finally show up not hidden to the RAX80. Not sure why. I never used the WPS before so I didn’t try it. Maybe next time if I have to reset it. Do you push the WPS on the router first? Is it secure?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 819 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
